Machine Vision
Detect interruption in contour?
Hi guys,
is it possible with Vision Development Module to detect a contour and further to detect if it is interrupted or closed?
A colleague of mine explained to me a method using a lasso tool. If a shape, for example a square with side length "a" is complete, the lasso envelops it completely from outside. The resulting lasso length would be slightly larger than 4*a.
But if the square is interrupted in one or more locations, the resulting contour would be enveloped from the inside as well, giving a lasso length much larger than 4*a. Thus it should be possible to detect the interruption.
I have attached an image to illustrate.
Thanks!
(4,877 Views)
Hi there,
How are you currently doing the lasso? Could you sent us an example code?
Certified LabVIEW Architect (CLA)
(4,846 Views)
I do not have that many info, but with what I have (everytime a square, with only one interruption) you could try to use the Clamp as minimum and if the distance is lower than a certain value, you will know that the square is not full.
See the attached image.
Hope that is helping you.
(4,829 Views)
Yes, here it is attached.
(4,799 Views)
Need a second post for the fourth attachment, only three allowed.
Here is the code itself.
It basically works, but depending on the settings the algorithm seemingly cannot determine a "correct" contour if the case is not exactly clear. That is if the right border of the outer frame is still there but is dark and barely recognizable.
(4,798 Views)
