Machine Vision
Determining the position of the camera in space
Dear colleagues!
I had a task to determine the angle of the camera in relation to the plane. There are 3 spheres on a plane at equal distances from each other. I have a complete set of LabVIEV and Vision. The task is next. According to the coordinates of 3 points on the 2D camera matrix, determine the angle and direction of the camera tilt, provided that the numbers of the balls are recognized. Thank you in advance!
(1,927 Views)
Hi Vadim_Makeev
if I understand correctly what you trying to do is to detect the deviation of the camera from normal position, aren't you?
Also. I would link to know in which environment are you using LabVIEW or Vision Builder? What did you try before to solve the problem?
I think you should try to have a default value and continually compare it with different positions of camera.
Regards)
(1,707 Views)
Hi l.hovs! For development, I use both environments depending on the task. My question is mainly in the field of mathematics. With the help of image processing, I can determine: 1. The position of the centers of the spheres in a flat (matrix) coordinate system. 2. I can determine with good accuracy the diameters of the projections of the spheres.
The mathematics itself is needed for converting a flat image into 3D space coordinates
(1,699 Views)
Hi Vadim_Makeev
I have found a LabVIEW code example how to convert the image into a 3D textured heightmap
Try to go through that article and replicate teh code in your side to see what will be the results.
Regards)
(1,627 Views)
Thank you! I will definitely look into this option!
(1,594 Views)
