Machine Vision
Diameter of bottle detection using Machine Vision is it possible ?
The camera will be placed arround 10cm from the conveyor belt and the bottle..
The camera will be ordinary webcam since high speed and high resoultion cameras are expensive in INDIA
Message 11 of 25
(2,395 Views)
also when I load this onto VIsion and try to do something in Machine vision I get this  error message stating that :
The image is a 32 bit RGB while edge detector supports only 8bit,binary ,16 bit
what should i do ?
Message 12 of 25
(2,395 Views)
You still have not  provided me with your personal mail id.
Message 13 of 25
(2,395 Views)
what should i do ?
There is a function called "Extract color planes" Use this and select luminance plane.Your edge detector shld work
Message 14 of 25
(2,396 Views)
I have attached the mail id in the picture ..
I dont like to be spammed..
thank you
Message 15 of 25
(2,393 Views)
For your info nobody likes to be spammed
Message 16 of 25
(2,392 Views)
please email if you can give any guidance ?
like what tools to use etc
Message 17 of 25
(2,390 Views)
Try using the clamp function directly first.Tweak a little with the smoothening the edge strength.Then you will come to know the filter that u might need to apply.
Message 18 of 25
(2,383 Views)
please send me your id so that i can keep in otuch with you
Message 19 of 25
(2,375 Views)
Will send you the links and materials to the id uhve given from my personal id.
Message 20 of 25
(2,360 Views)
