Machine Vision
Do PixelValue2D properties return a new array, or a reference?
I'm writing a program to acquire data from an IMAQ device to a ring buffer, and operate on the data from there. I'm extracting a PixelValue2D, and I'm curious about how it works.
I want to access the data as a short[,], so I write:
PixelValue2D pixVal = _session.Acquisition.Extract(bufferNumber, out bufferNumber).ToPixelArray();
short[,] imgData = pixVal.I16;
Does the pixVal.I16 return a reference to the data, or a new copy of the data? This information will be very helpful for keeping my program as efficient as possible.
Thanks!
Message 1 of 16
(6,499 Views)
Hi middletongard,
Could you tell me which language you are working in so that I may be of better assistance?  I have not been able to find a reference to this function.
Lynn
Senior Systems Engineer
Message 2 of 16
(6,471 Views)
C#
Message 3 of 16
(6,470 Views)
I found information for PixelValue2D.I16 here within the Visual Studio 2008 help:
ms-help://MS.VSCC.v90/MS.VSIPCC.v90/NI.MeasurementStudio.2008/NINETVision/html/NationalInstruments.Vision.PixelValue2D.I16.html
PixelValue2D.I16 Property
Gets the pixel values for images of type I16.
[Visual Basic]
Public Property ReadOnly I16 As Short(,)
[C#]
public short[,] I16 {get;}
Property Value
The pixel values for images of type I16.
See Also
PixelValue2D Class | PixelValue2D Members | NationalInstruments.Vision Namespace
Message 4 of 16
(6,469 Views)
Hey!
Ah yep, I found that right after you.  Well I'm glad you've got a solution. Best of luck with your application!
Lynn
Message 5 of 16
(6,467 Views)
Ah, I don't have the solution quite yet - the information does not tell me whether a copy of the data is made, or a reference to the data is returned.
If this information is implied in the definition, I haven't caught it. Could you please find out and let me know explicitly whether a new copy of the data is made and returned, or it's simply a reference to the data in PixelData2D (no copy) that is returned?
Message 6 of 16
(6,465 Views)
Hi middletongard,
It appears as though the PixelValue2D is ImaqBuffer which a a zero-copy operation.
Lynn
Message 7 of 16
(6,445 Views)
Similar to middletongard, I'm trying to acquire IMAQ data in C# and extract the data into a short array for further processing. From the last post I see that extracting PixelValue2D from ImaqBuffer is a zero-copy operation, but I still wonder whether new memory is being allocated?
The reason I ask is that my application crashes with an OutOfMemoryException after running for a couple seconds.
This is the line of code that generates the exception:
short[,] data = mSession.Acquisition.Extract(BufferNumber, out CurrentBufferNumber).ToPixelArray().I16;
And this is the relevant part of the stack trace:
Exception Info: System.OutOfMemoryException
Stack:
   at NationalInstruments.Vision.Internal.Utilities.ConvertIntPtrFlatTo2DArrayInt16(IntPtr, Int32, Int32, Boolean)
   at NationalInstruments.Vision.VisionImage.ImageToArray(NationalInstruments.Vision.RectangleContour)
   at NationalInstruments.Vision.Acquisition.Imaq.Internal.ImaqVisionImageBuffer.ToPixelArray()
   at NationalInstruments.Vision.Acquisition.Imaq.ImaqBuffer.ToPixelArray()
Note that the exception is thrown from ToPixelArray(), not getting the I16 property.
I would appreciate any help I can get!
Message 8 of 16
(6,180 Views)
Accessing raw pixel data as an array out of a Vision image is always a copy operation. Otherwise there is no way to properly synchronize access between the Vision image's access to its internal data and the user's access via the array.
Eric
Message 9 of 16
(6,177 Views)
Thanks for the quick response Eric, that definitely makes sense to me. But my issue is with the memory allocation rather than the copying. I would like to reuse memory instead of repeatedly allocating and freeing.
A desireable solution would be if I could pass in the destination array when extracting the data, i.e.:
//During initialization
   short[,] data = new short[xSize, ySize];
//Later, during acquisition
   mSession.Acquisition.Extract(...).ToPixelArray(out data);
I know that call doesn't exist, but I wonder if there is a workaround for it.
My application can't afford to run the garbage collector during acquisition, so the goal is to allocate buffers before the start of acquisition and then reuse them.
Message 10 of 16
(6,173 Views)
