Machine Vision
Does Otsu adaptive thresholding method exist in labview?
Hi
I am developing an application for image processing. I need Otsu adaptive thresholding method. May I find it in labview NI Vision Assistant ready to use or I have make it myself?
Best regards
(6,821 Views)
It does. The  Otsu method maximizes inter-class variance. If you are using Vision Asistant you have to use Threshold -> Auto Threshold: Inter Variance. If you are using LabVIEW you need to use function  "IMAQ AutoBThreshold 2 VI" selecting inter-class variance method.
___________________________
Dawid Wozny
Certified LabVIEW Architect
Certified Azure Administrator
(6,820 Views)
