Machine Vision
Does PCI-1410 support RS-343 video source
I'm trying to acquire RS343 video signal using the PCI-1410 card. I just want to known if this card supports this signal. I tried to configure the card using the tutorial "Configuring the PCI-1410 with a non-standard camera or video source" but I wasn't able to perform video acquisition.
Maybe it's just because I didn't fill the appropriate parameters in the configuration file or maybe it's just because the PCI-1410 didn't support RS343?
So, if someone can provide me some help about the configuration file, which fields should be modified to succesfully acquire RS343 video source.
Message 1 of 9
(5,003 Views)
Dear JG,
I'm posting the results of our e-mail discussions from the service request you created for the forum:
I've been checking on a couple of the parameters in the file you sent me to see if you will actually be able to acquire the RS-343 signal. I thought it was going to be OK, but based upon the Pixel Frequency listed (68.464286 MHz), it won't be possible. The PCI-1410 has a maximum PCLK frequency of 40MHz, which won't be sufficient to acquire your signal.
The following is an example with numbers from the RS-170 standard. I did the same PCLK calculation with your numbers to verify:
Parameters of interest:
# of lines/frame: 525 (this includes 485 lines for display; the rest are VSYNC lines for each of the two fields)
line frequency: 15.734 kHz
line duration: 63.556 microsec
active horizontal duration: 52.66 microsec
# active pixels/line: 640
Now, some calculations we can make:
Pixel clock (PCLK) frequency (the frequency at which each pixel arrives at the frame grabber):
640 pixels/line / 52.66 e-6 sec/line = 12.15 e6 pixels/sec (12.15 MHz)
Total line length in pixels of active video + timing information (referred to as HCOUNT):
63.556 e-6 sec * 12.15 e6 pixels/sec = 772 pixels/line
Frame rate:
15.734 e3 lines/sec / 525 lines/frame = 30 frames/sec
Best Regards
~NH
Message 2 of 9
(4,978 Views)
Whatever came of this?  Has anyone successfully captured RS-343 video with a NI frame grabber?
- Brad
Message 3 of 9
(4,595 Views)
Hi Brad,
I am pretty sure that the RS-343 standard is not supported by any of our framegrabbers. However, I will check this and get back to you.
Vivek Nath
Machine Vision
Message 4 of 9
(4,570 Views)
I personally think it is not possible. Had a conversation long time ago going regarding this with NI. Not sure If they have done something regarding this lately..........
Message 5 of 9
(4,564 Views)
I just want to clarify that none of our framegrabbers officially support the RS-343 standard.
Vivek Nath
Machine Vision
Message 6 of 9
(4,555 Views)
I just want to clarify that none of our framegrabbers "officially" support the RS-343 standard
 Is there a catch?:smileyvery-happy:
Message 7 of 9
(4,534 Views)
No :-). All this means is that the RS-343 standard is not supported by our framegrabbers.
Vivek Nath
Machine Vision
Message 8 of 9
(4,524 Views)
ok so that concludes it for the "time being"Smiley Tongue
Message 9 of 9
(4,514 Views)
