Machine Vision
Does Vision Assistant have theAlgorithms.Resample functionality
Am I just not seeing it, or is there no way to resize (Resample) an image in Vision Assistant?
It would seem to me that resizing an image is one of the most basic image processing function.
I used to have to open images in MS Paint to resize, then reoppen in Vision Assistant.
I've created a resample VI which works. But I just thought that would be part of the basic functionality.
(5,804 Views)
Accepted by topic author JohnW242424
Yes, the resample function in Vision Assistant is located in the first tab (Processing Functions: Image). Choose the Geometry step, then select Resampling.
(5,799 Views)
It is not available in Vision Assistant, but the function is available in LabVIEW.  Did you just create a wrapper VI for it?
Okay, apparently available but well hidden.
Bruce
Bruce Ammons
Ammons Engineering
(5,796 Views)
ok friend  do this
open image in vision assistance  in first line of  icons select geometry setup and then select resampling this is what you want look this image it is what where you have to go to use
(5,783 Views)
Thanks...would have never looked there.
Actually, I will probably still use the VI I made becasue I can simply give it a multiplier (X2, X5, etc...)
vs. needing to calculate a multiple of the height or width then enter it in.
But, still nice to know that it does exist.
(5,773 Views)
so if it is true do not forget my KudosSmiley Happy
also it is better to accept it as solution
to help other find out wirte answer Smiley Happy
(5,760 Views)
