Machine Vision
Does imaq pattern match use frequency domain techniques?
I am looking into writing additional image analysis functions to support
my vision application.  I am wondering if the IMAQ Match Pattern function
uses frequency domain techniques (such as phase correlation).  The Vision Concepts manual talks
about FFTs and filtering, but it appears the pattern matching is performed
in the spatial domain.  Am I right?
Eric
(3,086 Views)
Hi Eric,
          NI Vision team demonstrated their pattern matching technique in one of their webcasts on the website. They look for contrast zones to extract edges (Stable Points). this process is done in spatial domain.
         I only can assure you that pattern matching with IMAQ is very competitor to its other software as the accuracy and speed is compelling that Would make you regret that time you wasted with other software.
        I posted a demo on the forum that used pattern matching in object tracking. This might give you an idea about the real power of IMAQ.
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
(3,075 Views)
