Machine Vision
Does the CWIMAQViewer.ZoomToFit property exist? Using C#.
CWIMAQViewer.ZoomToFit property is listed in the NI Vision (8.6) documentation but it does not seem to exists. I am using C#. Is this a bug?
John A. Lively
NDE Engineer
Pratt & Whitney
(4,181 Views)
Accepted by topic author Pratt
Here is the property you are looking for:
CWIMAQViewer1.GetCWIMAQViewer.ZoomToFit = True
One of the smartest colleagues here found it Jim9772
I hope helps you and everyone who is searching for it.
Please accept my regards.
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
(4,169 Views)
The actual C# syntax is:
CWIMAQViewer1.GetCWIMAQViewer().ZoomToFit = true;
I saw this method, but did not investigate. This means the Ni Vision documentation is wrong. Thanks for the help.
John A. Lively
NDE Engineer
Pratt & Whitney
(4,161 Views)
Hi Pratt,
Would you mind telling me specifically which documentation you are speaking of and where you found it?  I will have it corrected for you to avoid confusion in the future for others like you.  Thanks!
Kristen H.
(4,154 Views)
The only help I have found for C# is the VB help "cwimaq.chm". This is where I found the property. In the future it would help if C# documentation (syntax) is provided also. If you need more information let me know.
ZoomToFit Property
Syntax
Data Type
Boolean
Purpose
Boolean value that specifies if the display should automatically resize the image to fit in the viewer.
See Also
ZoomScale
John A. Lively
NDE Engineer
Pratt & Whitney
(4,152 Views)
Kristen,
The documentation didn't mention the calling path as implemented. I hope in VDM 2009, the new hirearchy of native .NET classes is illustrated as expected.
Cheers
Assistant Lecturer
(4,149 Views)
