Machine Vision
Draw rotated oval overlay
can anyone tell me how to draw a rotated oval overlay over an image, without having to rotate the image twice (as in https://forums.ni.com/t5/Machine-Vision/How-do-I-draw-an-ellipse-in-IMAQ/td-p/1666796 )? Rectangles are no problem, but I have not found a way to draw a rotated oval. Using Labview 2018SP1 with Vision.
Thank you.
(2,563 Views)
This is a problem for me too.  Frustrating that setting the angle on an oval is not a thing.
(2,228 Views)
OK, I brute Forced a solution.  Here is a snippet.  The output of this VI feeds into "IMAQ overlay points".   If you are using Imaq particle analysis to generate the minor / major axis, you will probably want to divide both by half.  Let me know what you think.
(2,217 Views)
