Machine Vision
Drawing the contour of the particles found by ParticleReport
I use Vision Module 2009 for .NET and c#
My question is how I can draw the contour of a particle found by the ParticleReport(). I tried GetPointsOnContour() but this delivers not the complete outline.
Furthermore I want to use this particle as a ROI for further operation.
Thanks for your assistance.
(3,435 Views)
Accepted by topic author Jürgen Cramer
The same problem is addressed for LabVIEW here:
http://forums.ni.com/ni/board/message?board.id=200&message.id=14826#M14826
However,  you are using.NET. Luckily, the same concepts still apply. Instead of the LabVIEW VI "IMAQ MaskToROI", you should use the method MaskToRegions.
Kevin C.
(3,410 Views)
This is exactly what I am looking for. But in .NET the algorithm is also MaskToROI().
(3,388 Views)
