Machine Vision
Dual cameras on 1430 board.
I'm trying to run 2 instances of the HLGrab sample applications to acquire from the 2 cameras plugged into my 1430 card.  I can grab from both camera individually (using img0::0 and img0::1), but I can't grab simultaneously.  When I try to start the second, I get this error message when calling imgInterfaceOpen: "The requested image acquisition device is already in use.".
How can I open both interfaces at the same time?
I'm using the very latest SDK (19).
Martin
(2,003 Views)
I found out that you can't access the 2 interfaces from separate processes.  Acquiring from both cameras inside a single process works fine.
(1,933 Views)
