Machine Vision
Dual core test
Hi
I have an image analysis program that sadly runs too slow on my current computer. I have to run at 40 Hz but can only run at 30 Hz on my AMD64 3700+ computer. I have tried to make the computation parallel in two threads to make use of dual core cpu's and would like someone with a dual core cpu to see if it helps.
If you have a AMD X2, Pentium D or Core 2 DUO cpu, please try and run this application - I really need your help!
All you need to do is unzip the files (one application and 50 data files) into a folder and run the application. Remember to type in the path for the data files in the program.
After you run it please post a screenshot of the program showing the computation times (i want to know if "P.loop time" is smaller than "S.loop time"). I have attached a screenshot from my own computer.
Simon
Files:
Message 1 of 1
(3,567 Views)
