Machine Vision
ELLIPSE FITTING
Hi! I'm trying to get the Ellipse fitting for a scattered data using the NonLinear Curve Fit, but I'm trying to use the general equation :A*x^2+B*x*y +C*y^2+D*x+E*Y+F=0 because the data present rotation from the original axes, but  when I changed the Model, the parameters that I got were almost zero everytime that I've tried. I was wondering if there is another way to introduce the model to the VI or if there is another way to do that. Unfortunatelly I don't have NI Visual Detection module or the IMAQ, so I'm stuck in here. Can somebody help me please?
Message 1 of 12
(8,824 Views)
Hello Andrea. I recommend you to check the Fit ellipse VI: labview\examples\math\curvefit.llb. This example was developed for non rotated ellipsed. But you can try to implement your own model and modify the parameters to include an angle.
An general equation for an ellipse can be found in this page:
http://www.maa.org/joma/Volume8/Kalman/General.html
This is a good start point.
Regards.
José Manuel Vólquez Rodríguez
Applications Engineer, National Instruments México.
Message 2 of 12
(8,811 Views)
Hello Andrea,
I have a vi from 8.6 maybe you can use it.
Please let me know if you improved it.
In the diagram are some pictures which formular i used.
Toine
Message 3 of 12
(8,791 Views)
why your examples of Ellipse_X_Y_Length.vi  can run?
Message 4 of 12
(8,313 Views)
I added the 2 missing vi's.
Toine
Message 5 of 12
(8,300 Views)
Thank you.
I want to ask your ellipse can use to detect mango in picture?
Message 6 of 12
(8,294 Views)
leon,
can you attach a picture? I can have a look.
Toine
Message 7 of 12
(8,276 Views)
Toine,
These are the mango picture.
Message 8 of 12
(8,259 Views)
Toine,
How? Can detect the mango picture?
Message 9 of 12
(8,196 Views)
Hello Leon,
There are several ways in machine vision to detect the mango.
Main key is that there is a difference between the mango and the background.
Overlapping mango’s is more difficult then a single one.
If other light source or filter will enhance the difference between the mango and background it will help a lot.
Possible methods:
- Curve extraction
- Morphology
   * Texture detection
   * Object
- Shape matching
I think shape matching will work the best in this case. I do not have experience with that. So look around on the forum.
I added a morphology example to test your mango. Only the first picture this will work.
With kind regards, Toine
Message 10 of 12
(8,177 Views)
