Machine Vision
ERROR 107439 71500l - Vision Aquisition - a timeout error occured while waiting for the specified...
I am using a JAI camera, then I want to captured a few images, so i select Finite Acquisition With Post Processing with 5 or more images to capture,
When i start to test it, it always shows
Error 10743971500l
NI. IMAQ: A timeout error occured while waiting for the specified event.
If waiting for an image, verify that all video data is acquired withing the time period.
If waiting for a signal, verify that the signal assertion occurs within the timeout period
How to solve this problem?
Thank YOU
Message 1 of 10
(4,924 Views)
I think it might be because of the initialization problem with the camera... But am not sure coz i have not used the JAI CCD cameras... check the initialization by setting break point...
Smiley Wink
There may be always some good solution left unposted
Message 3 of 10
(4,904 Views)
Single capture is working well.
Only if I want to capture more than one image.
Message 4 of 10
(4,895 Views)
can you post the BD you made..
Smiley Wink
Message 5 of 10
(4,887 Views)
the same error notification as i posted earlier 😃
Message 6 of 10
(4,884 Views)
I am still having the same problem.
I couldnt get rid of the timeout error =(
Any solution guys?
Message 8 of 10
(4,793 Views)
I was told that the problem is most probably because of the resolution of the image is too big.
Message 9 of 10
(4,761 Views)
I used the IMAQ SetImageSize element and resized the IMAQ and the error was solved.
Message 10 of 10
(1,105 Views)
