Machine Vision
ERROR -1074396120 imaq readfile
hello everyone:
i am using imaq readfile  to read a picture in my hard disk. the format of the picture is tiff, the data format in the picture is 16bit, but i get error-1074396120, i have tried grayscale I16 and grayscale U18, did anyone have met this before? thanks for your help
Message 1 of 8
(4,305 Views)
-Plenty of problems with your code.
-Use Error wires to enforce dataflow instead of Sequence structures.
-There are two IMAQ Read files which one is throwing error?
-You should provide the code and your images which you received error to debug or help.
-Also there are lot issues while reading TIFF file format files, How you got these images? Can you change the format to some other format?
uday
Message 2 of 8
(4,279 Views)
thanks for your reply, here is my  answer to your question:
-i have not notice the error wires,i do not think it is a key point,because the first Read Files do not work;
-both of the IMAQ Read Files throw error;
-i will provide them in the accessory;
-i got those images by a camera made by ourselves, i can save images in fit format, but i have not seen knowledge about reading fit files in labview, is there another way read tif files in labview? in fact, i can read those tif files in matlab using imread function. i tried to use MathScript and imread to read the image,but i have found that imread in MathScript does not support tif format, it just works for jpg,bmp and png.
Message 3 of 8
(4,263 Views)
i am trying to update the tif image,but  it is said that the image is Invaild File Type.i do not know why. i can see its property,and it show me the file type is tif. i can read it in Matlab.i guss it is tif image.
Message 4 of 8
(4,260 Views)
-My first point is referring to this: http://www.ni.com/newsletter/51735/en/
-Try uploading the images in Zip.
-I saw you were trying to calculate mean? There are VIs available in LabVIEW itself no need for Mathscript(Look into https://www.ni.com/docs/en-US/bundle/ni-vision-labview-api-ref/page/imaqvision/image_processing_pal....)
uday
Message 5 of 8
(4,256 Views)
http://pan.baidu.com/s/1bV3ThG thanks for your advices, zip did not work too. i upload it in a cloud strage and make a link,you can click it and try to download it.
Message 6 of 8
(4,248 Views)
Getting error like below:
uday
Message 7 of 8
(4,244 Views)
Thanks, you can try this http://pan.baidu.com/s/1nv9dcLj   the code is nks8
i am happy that you can visit BaiDu.cloud disk.
Message 8 of 8
(4,242 Views)
