Machine Vision
Edge detector information (vision)
I’m using vision to detect disturbance in a pattern. But there are 2 different kinds of disturbances. The different between them is at one disturbance all of the colors (green red and blue) decrease in intensity and by the other one just 2 colors decrease in intensity and one increase in intensity. The program I’ve to make, has to see the difference between the 2 kinds of disturbance and have to gif the coordinates of were the disturbance is.
Can anyone tell me if this is possible? Can I get these values out of the edge detector?
Thank you in advance,
Twan
(3,205 Views)
Here is a VI that shows how to separate the 3 color planes and turn them into grayscale image, you can then use the IMAQ find edge VI on each plane separately.
I hope this helps you
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,201 Views)
