Machine Vision
Error 0x80040275
Dear Sir,
I try to connect a GigE camera to my laptop. I plan to use it with VBAI software. My camera model is from imaging source, DFX41BG02.H. While I try to integrate it through Max, I encounter a problem with error code 0x80040275. When I close the error window, the Max show red x symbol next to the camera. Picture attached. Please advice
(4,470 Views)
It appears the camera is being detected as a DirectShow camera vis the camera vendor's drivers. That error is being returned by that driver. Are you sure that is a GigE Vision camera?
Eric
(4,461 Views)
