Machine Vision
Error -1074395384 occurred at IMAQ Match Color Pattern
Hi, I am new here. I have problem with IMAQ match color pattern ( in "Merenje ugla.vi") , but i don't understand why, what is problem?
merenje brzine vetra.vi
srednja vrednost.vi
(4,298 Views)
Error says invalid color template image.
-You need have valid color template to match with.
-Suggest you to check the example http://www.ni.com/example/30548/en/ and learn the template learning and setup process.
-You can find the example in Help->Find examples->Search for Color Pattern and then you can operate.
uday
(4,271 Views)
we have to kind of color matching template image
1 just color matching
2 color pattern matching template
if you use one of these template with other matching method you will get error
for example using template 1 for color pattern matching you will be find error massage
(4,248 Views)
