Machine Vision
Error -1074395997
Hello all,
                     I have written a VI in labview 8.2 to detect motion for the use in speckle interferometer. I am using PCI1411 frame grabber and PULNIX2013 MODEL CAMERA. At the moment everything is working fine but when i try to save image to a filei get error code with number Error-1074395997. Could somebody help me in this regard? THanks in advance.
visu
(4,379 Views)
 visu
Sounds like an invalid file path. Put a probe or indicator on the file path wire and see if it is correct.
It also looks like you have a floating T/F constant Save control over your case statement frame.
-AK2DM
Message Edited by AnalogKid2DigitalMan on 05-19-2009 01:13 PM
(4,368 Views)
