Machine Vision
Error 1074396024
Hello All
Im using a Logitech cam and the IMAQ USB driver but i cant run any of the applications like Grap, Snap and such ?
I get the error messages :
Error 1074396024 occured at IMAQ USB Init.vi
Error System
Can anyone help ?
(4,197 Views)
More info :
Windows XP, danish, SP2
Lapview 7.1
Logitech Quickcam for notebooks PRO
IMAQ USB driver from this site ;o)
(4,186 Views)
Hi Brian,
It looks like you have run into a language problem. The Direct show driver for USB cameras returns language specific strings for certain functions. Apparently on non-English OS's, the driver returns the capture pin string in the OS language, so the english string isn't found. We are currently working on a solution for non-English version, but I don't have a definite date to when that will be released. The driver does work on the English version of XP, so this is your best current solution. Let me know if you have any further questions.
Regards
Meister, NIDK
(4,153 Views)
Thanks for your clarification about this subject. I run onto the same error with my Finnish windows. I also read on the webpage (http://www.adras.com/more-imaq-usb-problems.t5733-148.html) that it has something to do with the architecture of directshow. On the same website is also a link with information how it can be solved, but unfortunately that link is out of date.
It there by now mayby some more inforation about how we can catch this problem?
w.k.regards,
Andries
(3,904 Views)
