Machine Vision
Error -1074396116 occurred at IMAQ CalibrationTargetToPoints
Error -1074396116 occurred at IMAQ CalibrationTargetToPoints, So there any one to solve this problem and thank you.
(5,760 Views)
How are you selecting the calibration? Can you post your vi?
(5,752 Views)
there is the VI and the picture of device. SO i need to calculate the dimension and thank you
(5,749 Views)
i have solved this problem but  i have an other problem and i put the VI
(5,744 Views)
Hello,How did u solve the error "insufficient number of calibration feature points" please?
(3,448 Views)
Hey Ons,
You're commenting on a 3 years old post so I wouldn't expect a response from the original poster.  If you do need some help with an issue you are having I'd post some code that is afflicted, images of the error you are seeing and information on troubleshooting you have done yourself.
That'll get us started at least!  Also, check out other forum posts with that error.
-Bear
Ben Johnson
ʕง•ᴥ•ʔง
(3,426 Views)
