Machine Vision
Error -1074396120 "Not an image"
Hello everybody,
I am currently using 2 Point Grey Research Greyscale digital video cameras with 2 PCI acquisition cards.
Both cameras work separately, but I have a problem with the following VI (see attachement "viscreenshot"). The following error message appears when I execute it:
Error -1074396120 occurred at IMAQ Resample - Not an image
You will find enclosed this message 2 screenshots, 1 for the error code and the other for the VI.
Thank you for your help,
If you have any question, feel free to ask
Odna
Message Edited by Odna on 07-30-2008 09:00 AM
Message 1 of 13
(6,213 Views)
check the attachment.Hope it helps!!
Message 2 of 13
(6,204 Views)
Dear Muks,
I will give it a try, thank you for your help. I come back to you soon.
Odna
Message 3 of 13
(6,199 Views)
Odna,
           Below in your block diagram you have again used the same buffer name (Right cam,Left cam).Also change it.Try using different buffer names for imaq create to avoid getting overwritten.
Message 4 of 13
(6,195 Views)
Musk,
where should apply what you've proposed in the picture named buffer1.png?
Message 5 of 13
(6,190 Views)
In the resample vi.You have something called Image dst(destination).Hope u get it
Message 6 of 13
(6,186 Views)
In addition to what i said above check this link
Message 7 of 13
(6,184 Views)
Message 8 of 13
(6,183 Views)
Muks,
here are the changes that I have applied to both Resample at the top, is that correct?
I haven't tried changing the buffer name (Right cam/Left cam), I will try this now.
Message 9 of 13
(6,170 Views)
Odna,
          Yes that is what i suggested.Hope your problem is solved.If not post your vi for 8.0.
Message 10 of 13
(6,122 Views)
