Machine Vision
Error 1074396120 with Image To Image2
^ Thanks for the suggestion.  I tried it, but still have the same problem.  For reference, here's what the VI looked like:
It it makes a difference, I'm useing the ThorLabs DCU223M camera:
http://www.thorlabs.com/NewGroupPage9.cfm?ObjectGroup_ID=2916
Message Edited by BadNoodle on 07-14-2009 12:48 PM
Message 11 of 14
(1,478 Views)
Ok, here's something wierd.  I changed the camera index from 1 to 0, and it worked repeatedly, but the image was inverted ... ?  So I flipped it back and everything seems to be working for now.  I need to integrate it to the other VI to make sure, but here's what the working test setup looked like:
Message 12 of 14
(1,474 Views)
I'm not surprised you had to set the index to zero.  I had to set mine to one because a Firewire camera showed up as the first camera in the list.
As for the inverted image, I have never seen that before.
Randall Pursley
Message 13 of 14
(1,461 Views)
^ Thanks for your help.  Using your suggestions, I got this thing to work finally.  I integrated the changes into the orginal project and everything works like a charm.
Thanks again,
-Tom
Message 14 of 14
(1,458 Views)
