Machine Vision
Error -2147418113 when Open Camera Session
Hi
I am using an USB Camera for my setup. I always get an error message (-2147418113) when I start-up my PXI system and open the camera session. I see the camera in MAX and its also possible to read out the camera information. But it fails when I try to open the camera session or when I try to grab an image in MAX.
After re-connecting the USB Camera I dont see the error mesage anymore and everything works as expected! Is there a workaround the reinitialize the USB Port or..?
Thanks in advance
(4,180 Views)
I found some information about your error message. Maybe this helps.
Receiving Error -2147418113 "Catastrophic failure in xxx.vi" When Using ActiveX Server:
http://digital.ni.com/public.nsf/allkb/E0FA5D83F1E5276B86256C7E005FD83C?OpenDocument
Receiving Error -2147418113 "Catastrophic failure in xxx.vi" When Using ImageList ActiveX Objects:
http://digital.ni.com/public.nsf/websearch/86256A47004E16D18625687E0076727A?OpenDocument
An automation server cannot pass a pointer to the picture object's IPictureDisp implementation across process boundaries (This article was previously published under Q150034)
http://support.microsoft.com/kb/150034/en-us
Best regards
Suse
______________________________
Certified LabVIEW Developer (CLD)
(4,151 Views)
Hi Suse
thanks for your answer. I will check each link to see if there is a solution to my problem. I will keep you informed.
(4,120 Views)
Suse
I have updated all USB camera drivers, which solved my problem at the end! 🙂
Thanks!
(4,109 Views)
