Machine Vision
Error IMAQdx with Tuscen camera
In my lab computer that run with window xp and have labview 2013.
When I try to open my Discovery MH15 Tucsen camera I received  "Error 0x80040154 The configured external lighting mode is invalid".
On different computer (window 7 Labview2011) the MAX do recognize the camera, but Didn't see the attribute that I need such as "Exposure time"
How can I make MAX to operate the camera, or should I try different method?
Thank
Zehavit
(5,712 Views)
What is the interface?  USB?  GigE?  Firewire?
(5,705 Views)
It's USB interface and have directShow and twain driver
(5,690 Views)
Hi Zehavit,
Does the camera work from any other software? IMAQdx only makes calls into the DirectShow driver, and is only able to access attributes allowed by the DirectShow driver.
-N
Staff Certification Engineer
(5,685 Views)
Hi  Nathanael,
The camera work fine with the manufacture software ISCapture, in the last days  I manage to call the camera DLL by using the LabVIEW Call Library Function. I not understand yet how to use all the function that I need, but I have connection with the camera.
Thank
(5,653 Views)
