Machine Vision
Error Monitoring CVS application through web Browser
Im trying to monitor my cvs application through a web browser, but i have some problems with the imaging.
All the controls work fine, but the image do not update. In the CVS the image uptades fine, but in web browser no.
Anyone knows what could be?
thanks,
JeFF
(4,378 Views)
Hi JeFF,
This behavior is due to the RT architecture. Update the front panel is the last task the CVS will do. Actually, a RT application don't have front panel. Transfer images are a starving action. You need to transfer too much data.
You can make the CVS send data to your remote front panel, but it will decrease the performance of your application. You can send the data using a property node of the indicator and selecting the property Value. Then you link to these property node the acquired image.
Best Regards
Alisson Kokot
(4,351 Views)
