Machine Vision
Error from imgSessionConfigure During Grab
We are using NI PCIe-1429 frame grabber and Mikrotron MC1310 camera and are developing our application in VisualStudio 2010 C++.  Currently I keep getting the following error when calling the imgSessionConfigure() function:
"One or more buffers in the buffer list is not configured."
I have allocated 3000 buffers.  I don't get this error when doing a Snap.  Also I don't get this error when running the ll_grab example.  I copied most of the code over from the ll_grab example.
Can someone help me to figure out how to get beyond this error?
Thank you.
(3,221 Views)
Do you get an error code with that? Also, does it work fine in Measurement & Automation Explorer?
Cameron T
(3,206 Views)
