Machine Vision
Error in Deploying a VI on CVS-1458RT
While trying to deploy a VI on a CVS-1458RT, I get the following error at the end of the Deployment Status in the Deployment Progress dialogue box:
Deploying NI_Vision_Development_Module.lvlib:IMAQ Draw TextNI_Vision_Development_Module.lvlib:IMAQ Draw Text loaded with errors on the target and was closed.
LabVIEW: (Hex 0x627) The function name for the nivision.*:LV_DrawText_v2:C node cannot be found in the library. To correct this error, right-click the Call Library Function Node and select Configure from the shortcut menu. Then choose the correct function name.
Deploying NI-CVS-1458RT-01A1F26F Container
Deployment completed with errors
I have no problem running the code on my PC. Any idea what is going on?
(4,310 Views)
Hi SoheyIV,
Have you already deployed the VDM software to the CVS target? You can do this by right clicking the Software tree under the CVS-1458RT in MAX and selecting 'Add/Remove Software'.
(4,206 Views)
