Machine Vision
Error when deploying IMAQ Modulo, Divide, or Multiply
I am deploying to a CVS 1457RT and I have changed up my vision algorithm. Now when I try to deploy I get the following errors with the
IMAQ Modulo, IMAQ Divide, or IMAQ Multiply...
I only get one error during the deploy before it stops. I can go in and change the function to one of the others and get the next error.
I have an open ticket with NI on this issue but I need to get past this or figure out a work around. when I run this on my development system it runs with no problem.
Any Ideas?
Deploying NI_Vision_Development_Module.lvlib:IMAQ ModuloNI_Vision_Development_Module.lvlib:IMAQ Modulo loaded with errors on the target and was closed.
LabVIEW: (Hex 0x627) The function name for the nivision.*:LV_Modulo2:C node cannot be found in the library. To correct this error, right-click the Call Library Function Node and select Configure from the shortcut menu. Then choose the correct function name.
Deployment completed with errors
Deploying NI_Vision_Development_Module.lvlib:IMAQ DivideNI_Vision_Development_Module.lvlib:IMAQ Divide loaded with errors on the target and was closed.
LabVIEW: (Hex 0x627) The function name for the nivision.*:LV_Divide3:C node cannot be found in the library. To correct this error, right-click the Call Library Function Node and select Configure from the shortcut menu. Then choose the correct function name.
Message 1 of 1
(5,143 Views)
