Machine Vision
Error when try save a template. Error Message -1074395247: Invalid template descriptor when use the template in the Macth Pattern
Hello to all,
I m trying to create one template through one image that i have and then i try to use this template in a match pattern and it give me error. The problem i think is the method that i use to create the template is not valid and i dont know why.
Anyone can help me.
I put one example to explain what i trying to do.
I use the labview 8.5.1, and the vision 8.5
(3,660 Views)
Bonjour,
Vous trouverez surement la réponse à votre question dans ce document:
http://digital.ni.com/public.nsf/allkb/F05924D50AD6472B86256F320075CDBF?OpenDocument
Cordialement,
Manuel R
AE dans une autre vie
(3,598 Views)
