Machine Vision
Executable with NI-IMAQdx
Please is it possible to include NI-IMAQdx as part of executable during the build process? Trying to fulfil this policy:
http://digital.ni.com/manuals.nsf/websearch/9B616EB9DE865E81862571D5005FB16C
(4,173 Views)
Hopefully yes,
You need the two license, then during the build, include IMAQdx installer:
Regards
(4,164 Views)
Hi aderogba,
As was mentioned above, the process should be relatively simple. You will just need to make sure that you include IMAQdx in an installer and have a license for IMAQdx (Vision Acquisition Software license) on each machine.
Below is the same screenshot in the English LabVIEW version.
I hope that's helpful!
Matt
NI Community Team
(4,155 Views)
Hi, i have a question: what is this for? (just to confirme)
And i don't have this option in my labview 2011 version !!
(4,055 Views)
This is to add the IMAQdx installer to your application installer.
You will see this option only if IMAQdx is installed on your development computer.
Regards
(4,052 Views)
