Machine Vision
Export Data to Excel in Table Form
Hi, is it possible if I want to export data in table form from NI Vision to Excel?
The current exported data that I got is just values and no table/border created.
(2,733 Views)
"Write Delimited Spreadsheet" should do it.   You might have to convert numeric data to text if there are mixed fields.
No borders, just filled cells. although There are a whole series of excel specific VIs that can do much more.
(2,701 Views)
How exactly are you exporting the data, and does "no table/border created" mean that all the data is being written in a single cell?
(2,686 Views)
I used "Data Logging" in Vision Builder. Then, I export the data to Excel. The data is written correctly according to its column and row as per below. However, there is no border (line) created.
I want the data to be exported automatically with border (line) as shown below. Please advise.
(2,674 Views)
Unfortunately, the "Data Log" tool seems to not give such opportunity. Although you can create a LabVIEW VI and try using the "Run LabVIEW VI" tool to programmatically create the borders.
These might be handy
Run LabVIEW VI FAQs ,
Custom Cell Borders in Excel with the Report Generation Toolkit
(2,656 Views)
