Machine Vision
Extract Color Pane Error
I am trying to create a program to track 4 different trackers with 2 cameras, however, while the program runs I keep getting the following error: Code-1074396080 IMAQ Extract Single Color Plane. Would anyone know why this error is there or how to fix it? I am using Labview 2011 and I have attached the file with my block diagram.
Thank you,
Anuja
(3,982 Views)
I have never tried to extract a color plane from a grayscale image.  The help also says, that it does not support this image type.
(3,954 Views)
