Machine Vision
Extract Contours From Irregular-Shaped Object After Video Pause
So I have an irregularly shaped object within an AVI video frame. I'm trying to play with the IMAQ Extract Contours function to create a complete silhouette of the object and then overlay it as soon at the user pauses the video. At least that's the goal. This function seems a bit touchy and I don't know if it's the best thing to be using. Does anybody have any better ideas? Or at least know what settings I should be using in order to get the best results out of this?
(3,753 Views)
attach some image to make your clear but for first answer use wang algorithm for border detection it is nice and you can find example of that in LabVIEW examples
(3,745 Views)
