Machine Vision
Extract a Circular ROI
Message Edited by vineet123 on 01-07-2009 02:17 PM
Message 11 of 23
(4,197 Views)
thanks for reply,
I am posting the code here....
Vineet
Message 12 of 23
(4,198 Views)
Can you post it for lv 8.0 or a screen shot of the vi?
Message 13 of 23
(4,183 Views)
Thanks for the reply. I am posting the code as well as the snap shot of my vi.
Vineet Agrawal
Circular ROI Extraction
Message 14 of 23
(4,174 Views)
In my code please ignore the first circle detected. I will use that circle also once i get through with one circle.....
Waiting for your reply
Vineet
Message 15 of 23
(4,159 Views)
Your Annulus cluster is being wired wrong.
The entries from top to bottom are Center X, Center Y, Radius Inside, Radius Outside......
You are telling it that the radius inside is some value X whereas the radius OUTSIDE (Which must be larger) is zero.
This is where your error is coming from.  Wire the Radius to the fourth terminal from the top and it should work.
Shane.
Message 16 of 23
(4,150 Views)
a lot of thanks...
I got it right..........
Message 17 of 23
(4,140 Views)
I'm also trying to extract an circular ROI,
after the extraction I want to binarize the image, only my threshold value
moves because of the black background.
Is it possible to onely binarize the extracted circular ROI?
or must it always be a square?
Greetz,
Chantal
Message 18 of 23
(3,581 Views)
Do you mean you want an image having the circular part alone in binary format and the rest of the image in grayscale???
Instead of the same image you can extract a circular roi as explained by andrew in this thread and extract the image and apply threshold. The image if extracted will be a rectangle
Message 19 of 23
(3,578 Views)
This is what I meant. Circular roi and circular masked region extraction
18349iB39BE4845EFFCC82
18351i69C5D76931185F24
Message 20 of 23
(3,577 Views)
