Machine Vision
Extract image using coordinate system
Hello
I have a simple question but I could not trace the problem pls suggest me in this. In my application I need to extract a part of image to display  on front panel from the image captured from the camera in which part of image to be displayed  is slightly deviated  every time . I constructed a coordinate system for the reference image and linked to the every new captured  image.  The operational rectangle to extract the image. using IMAQ extract is kept constant but i could not get the required part of image. There is no change in extract image operational rectangle even after the coor dinate system is included. pls find the vi attached.
(3,251 Views)
Hi
Here is a link to a previous post including some code that extracts rotated rectangles from an image. This should do what you want.
Extract Rotated ROIs
Hope that helps
Mike
(3,242 Views)
