Machine Vision
FPGA RAM
Hello everyone.
I am processing image by FPGA (PXI-7962R), and the question is the RAM is running out. Even though I just use the threshold.vi and centroid.vi,the rate is attach 98% .
I also want to use the lowpass.vi and kennel.vi to filter the image. Does there has the solution to reduce the rate of RAM usage. Thank you very much.
(2,159 Views)
Hello everyone.
(2,139 Views)
Accepted by topic author D.L.ZHANG
Hi  D.L.ZHANG,
What I suggest you is the steps in this article to optimize your FPGA resource Usage or Speed.
Regards
(2,109 Views)
