Machine Vision
File PAL.icd seems to be broken
While playing with some settings in MAX probably I did something wrong, I guess I have broken the PAL.icd file ... Should I overwrite it, if so where to find it.
That is what I see, when in the properties of the channel I want to change it to PAL. Other types work just fine.
(3,469 Views)
Accepted by topic author Deusto
I took the file from other computer, with the Imag installed on it. It´s a camera driver. But I edited the files (the "broken" one and the new one) and there was no difference between them ...
(3,453 Views)
