Machine Vision
(Filter?) Lines in Displayed IMAQ Image
Another trick is to acquire the image in color using the Bayer filters, then convert it to grayscale.  The end result is the same.  A little more complicated, but cheaper than getting the Development module for a single VI.
You might also be able to select a different mode for the camera so it outputs grayscale instead of Bayer color.
Bruce
Bruce Ammons
Ammons Engineering
Message 11 of 11
(1,772 Views)
