Machine Vision
Filter edge polarity
      I'm using the imaqEdgeTool to search edge along a line. There is an option to force the function to find only the positive polarity edges along the line, or I must manual delete the negative polarity edges in the EdgeReport result of the function ?
                                  ThankYou
(3,682 Views)
Gualty -
imaqEdgeTool() and imaqEdgeTool2() do not have any way to only find edges of a given polarity.  You will need to look at the polarity in each EdgeReport and manually delete those edges that do not fit your criteria.
Sorry!
Greg Stoll
Vision R&D
Greg Stoll
LabVIEW R&D
(3,668 Views)
Hi gregstoll,
       ThankYou very much for Your help.
(3,657 Views)
