Machine Vision
Filtering Particles based on multiple conditions
I have a general concept that I want to include in my labview VI but I don't see how / if it is possible. I am using all labview Vision VI's in my program. Basically, I want to filter out particles with holes in them only if the particle diameter is less than 30 pixels. If the particle has a diameter greater than 30 pixels, the particle will not be filtered out regardless of number of holes. I don't see how this can be done with the basic Particle Filter VI. So essentially I can't do the filtering seperately as they are dependent on each other. Please let me know if you have suggestions.
(2,517 Views)
Accepted by topic author carolinestephens
You can do it.  Set your criteria to diameter < 30 AND num holes > 0, then remove particles that satisfy both conditions.
Alternately, the conditions could be diameter > 30 OR num holes = 0, then keep particles that satisfy either condition.
I don't remember exactly how to combine the include/exclude and keep/remove, but you should be able to figure it out with a little testing.  Create a test image with all four possible combinations, and see what is kept or removed.  You can test it in Vision Assistant quite easily.
Bruce
Bruce Ammons
Ammons Engineering
(2,509 Views)
