Machine Vision
Find Concentric Circles
I know I can use Find Circular Edge to find circles individully, but I need to force them have the SAME center.
Is there a way to do that?
TIA
George Zou
(4,146 Views)
Hi George,
I am assuming that you are using NI-Vision. If so you can sse the IMAQ extract curves  to do what you need
Joe Daily
may the G be with you ....
(4,131 Views)
Thanks Joe.
This VI doesn't give me radius, nor center.
How do I get radius, and center from an array of points?
George Zou
(4,118 Views)
Hi George,
There is also the IMAQ find circles vi that will find the radius and center. Hope this helps
Joe Daily
(4,110 Views)
You mean Find Circles is better than Find Circular Edge ?
George Zou
(4,102 Views)
Hi George,
It depends on your application. I would test both and see what works best.
Joe Daily
(4,087 Views)
