Machine Vision
Find entropy value in an image
Hi All,
I have a grayscale image and the mask of the particles that I am interested in.
I want to find the entropy value of the particles selected in the mask image.
I looked up TSA entropy VI in signal processing toolkit, however I could not find anything for images.
How can I create this?
Test images are attached. I want to find out the entropy value for each coin shown in the image.
Regards
Aveo
(5,207 Views)
use the attached .vi to calculate the image entropy.
Of course you need to process each coin seperately, but as you've masked them, this is trivial.
P.S.: Since log has a base of 2, this is called Shannon entropy. You can use other bases, e.g. e or 10.
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(5,196 Views)
Thanks for the vi.
This is great. But how do I tackle the multiple particles problem?
One solution would be to run a for loop that  creates the mask of one particle in each iteration and then uses your vi to find out entropy.
However this might take a lot of time.
Do you have any other alternative for multiple particles?
Regards
Aveo
(5,190 Views)
I don't see how can the calculations for each particle be avoided.
Regarding the speed, it boils down to your specifications. How much speed do you need? I quickly tested an image with 1000 particles (size ~3000x2000 pix) and the calculation time was ~100 ms (low to midrange laptop). That's still 10 frames/s. This includes also thresholding and particle analysis (to get the actual roi's) - see below:
This way, you can also track the objects that deviate from average entropy for example.
K
(5,184 Views)
Even I believe there is no way to avoid the loop! Smiley Sad
(5,181 Views)
