Machine Vision
Find intensity of pixels in a region
Hi All,
I have a grayscale image, lets call it I1. Also I have a mask image that will enable me to select a specific region of I1. The mask can be irregular shape too.
I want to create a 1 D array that will give me the intensity value of all the pixels(corresponding to I1) that are covered by the mask only. This can be compared to what imaq Line Profile does, only in this case it should be extended to an irregular region rather than line.
Now one way to do this would be to convert the mask image into an array and use a nested loop to check whether the pixel value is 1 or 0. If its 1 then index out the intensity value from the grayscale image and build array. However this will take a lot of time.
Is there any faster way?
I was also wondering whether its possible to use the imaq histograph to construct the required 1 D array?
This can be done using the Histogram element of the outptut cluster since it has the info about how many times an intensity value has repeated in the image.
But still no idea on how to use this info.
Can anyone suggest an alternative?
Regards
Aveo
(5,338 Views)
Use IMAQ Quantify and your mask.  The global report includes the entire image, and the region report will be for your mask.  If your mask values are all 1, it should be the first region report.
Quantify can be very useful when you have multiple regions.  You use IMAQ Label to get a different intensity for each object in your mask, then the region reports are for each region in the image.
Bruce
Bruce Ammons
Ammons Engineering
(5,327 Views)
Hi Bruce,
Thanks for the reply.
Your suggestion works really great to find out the basic statistical entities such as mean, standard deviation and max and min intensity of different masks objects in the same image. However I just want to find out the intensity of the pixels that are there in a single object only.
Let me explain a little more.
Assume an image coin.jpg(see attachment). Now say I have a mask image that masks only one of the coins. I want to know the all the pixel intensity at those points in the mask as a 1D array.
I hope this explains the problem.
Regards
Aveo
(5,319 Views)
how about something like this:
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(5,296 Views)
Hi Klemen,
Thanks for the suggestion. It does work great!
However I think for  image (~ 300x300 pixels) it would take a little long due to presence of build array.
I came up with a faster alternative.
Its implement in the attached vi.
Regards
Aveo
(5,246 Views)
yes, your approach is far more efficient. But not that much on the account of initializing the array, but the histogram approach. Here lies the biggest difference. Using the histogram approach on build array speeds up the process significantly. But yes, it is always good to preallocate memory if possible - if you know the actual size to preallocate (definitly more efficient than build array I would say).
Thanks for sharing.
K
(5,242 Views)
