07-07-2010 09:28 AM
HI.
i am using Vision Builder AI 2009 to do my project. i need to use tis software to measure the angle between the original position to the new position of this item.i have been trying many way but i still cant cant my ans.
Here i have attach the sample of image that i use in the project.
07-07-2010 09:45 AM
My guess is that you have moved your illumination (most likely CFL) for those images to make sure you see the thick white marking. Am I right? First Try to make the illumination uniform then try pattern matching. It should work.
07-07-2010 09:57 AM
ya, i need to make sure tat the white marking can be c 1st. but i think pattern matching cant work cause i have try this method before, what it show me is only the item is match or not match.
07-07-2010 10:06 AM
You do get the angle of match as co-ordinate output right?
07-07-2010 10:12 AM
nope.
actually i get this idea but i don't known how to do it.
07-08-2010 12:27 AM
You've to use the lighting that can can light down directly on to toroid to cancel shading problem.
Then, detect bright object to detect center circle.
Set axis, and find edge.
