Machine Vision
Finding center and angle
@muks wrote:
The vi is just to give you an idea of how to save multiple images in the location. from your vi you are already using an express vi for image acquisition( i dont prefer that) so just ignore the imaq acquisition vis and see the image saving part alone.
Hello muks. Sorry for delayed answer. I used as your said(attached VI) and it works as well. I have question for you. Why do you prefer manual VI's over Express Image Acquisiton VI?
Message 31 of 47
(3,363 Views)
I feel it is easy for me to configure by not using express vis
Message 32 of 47
(3,358 Views)
Are you able to say is there any  performance diffrence between express VI's and manual blocks?
Message 33 of 47
(3,355 Views)
There are a lot of reasons
see this discussion
Message 34 of 47
(3,353 Views)
For vision express vis i fee there is a whole lot of actions taking place inside your while loop while just a simple snap image will suffice. Right?
Message 35 of 47
(3,348 Views)
Yeah I just need snap images at certain times and process them as I asked at previous pages and then show this processes' results.
Message 36 of 47
(3,345 Views)
Then as suggested use a int out side the loop and a close ot side the loop and a snap inside the loop.
Message 37 of 47
(3,341 Views)
Sorry for that but English is not my main language and I think you've some typos at your message so I could not properly understand what you mean.
Message 38 of 47
(3,335 Views)
I meant use a "initialize.vi" outside the while loop. Snap.vi inside the while loop. Define a image buffer (Imaq create.vi) out side the while loop and connect it to snap.vi. Use close.vi outside the while loop .
Message 39 of 47
(3,332 Views)
This is what you''ve said(at attached VI), isn' it?
Message 40 of 47
(3,328 Views)
