Machine Vision
Finding edge coordinates of a circle
Hello everybody,
I want to get the coordinates from the points on the perimeter of a detected circle. I use the "Find Circular Edge 2" vi, but the edge coordinates are missing.
Any help on this?
http://zone.ni.com/reference/en-XX/help/370281M-01/imaqvision/imaq_find_circular_edge_2/
(3,353 Views)
Use IMAQ Spoke instead.
http://zone.ni.com/reference/en-XX/help/370281M-01/imaqvision/imaq_spoke_3/
In the search lines cluster, you have the detected edges coordinates.
Hope this helps
Regards
(3,348 Views)
Thanks, in the meantime i found a solution. I used the "Find Circular Edge" VI, which has this feature. I used the Vision Assistant to produce the vi. But as I can see you can´t find "Spoke 3" in the Assistant. Thank you anyway, problem solved!
(3,344 Views)
