Machine Vision
Firevire camera & Driver problem
Hello Danilo,
is there still the issue with camera AVT Marlin F145C?
Lukas Bedajanek,
AE, Czech Republic
Message 21 of 30
(3,638 Views)
Hello Lukas!
Yes the situation is still the same.
Regards!
Danilo
Message 22 of 30
(3,636 Views)
Hi Danilo,
you wrote that the speed of  AVT Marlin F145 has increased but the acquired image was not OK. What do you mean by was not OK? Can you describe it little more.
Lukas
Message 23 of 30
(3,633 Views)
Hello!
Image has stripes inside the picture.
Regards!
Danilo
Message 24 of 30
(3,631 Views)
Can you sum up, what you have done so far that pictures from your camera has stripes.
I mean write what registry you have changed and could you please post the stripped picture?
Thank you
Lukas
Message 25 of 30
(3,623 Views)
Hello!
I'm using AVT drivers, Ihave changed registry For NI-IMAQ for IEEE 1394 2.0.x
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\imaq1394k\Parameters
AsyncTransferDelay = 0
When I changed this parameter speed is lower, but image is not OK.
Best regards!
DAnilo
Message Edited by danilo on 03-22-2010 07:26 AM
Message 26 of 30
(3,621 Views)
DAnilo,
I'm not sure what you are asking for. IMAQdx puts an artificial delay (5 millsec by default) in between 1394 register accesses to try to work around cameras that have problems if you write things "too fast." This is a bug in the camera because it the camera that tells us when a register operation completes and we wait for this to happen before going on to the next operation. The DCAM/IIDC specification that IMAQdx adheres to doesn't specify any notion of minimum delays between register operations because of this.
You removed the artificial delay and the camera started misbehaving. The only options would be to switch cameras to one that doesn't have this issue or put the delay back in.
Eric
Message 27 of 30
(3,598 Views)
i have dled the the bus driver, but doesn't seem to work on a 64-bit system.  do you know if there is a 64-bit version of this software?
Message 28 of 30
(3,413 Views)
Hi Veriatas
Could you be more specific which driver you have downloaded and what do you mean by "doesn't seem to work on a 64-bit system"? Do you see errors?
Could you also open a new thread with your question?
Barna D.
Message 29 of 30
(3,340 Views)
Hi Danilo and to all of you!
please, please, please, i've lost xp driver for f145c2
have you those drivers??
please help me!
thank you!!!
Message 30 of 30
(2,230 Views)
