Machine Vision
For VB.NET Experts, Measuring All sides of two figures
Briefly speaking, I have two shapes (images included). I'd like to match them with color template (done easily with Color Pattern Matching). I thereafter want to measure the length of each side (maybe using rake better than caliper I think since the actual images may not form perfect straight line).
So this could be smmarised in :
  • Find Each Color Pattern (score and angle)
  • Measure all four sides of each shape (in pixels, then conversion to real world unit is easy)
  •  display results
I know it is very trivial process. I blame myself for being away from IMAQ for 3 months. I'm under stress and hope to receive this help from my friends here.
I hope you can post "the solution project" and not only ideas. Thanks colleagues.
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
(3,371 Views)
What if you use CWIMAQPatternMatchReportItem.BoundingPoints to create another region for the rake or caliper...
Basically the steps are...
- Find color pattern
- use CWIMAQPatternMatchReportItem object to obtain detected pattern coordinates
- create a new region(s) based on the pattern coordinates for the Rake method to measure the sides
- display results
If I get a chance I'll try and create a simple application, looks like an interesting project...
(3,343 Views)
